Workflow to arrange cuts on workpiece?
I have been using onshape → krabzCAM → maslow.
One thing I don’t like about this workflow is arranging my cuts (as svg/dxf) in krabzCAM can be tedious. Often I’m looking to pack in multiple cuts in a constrained area. Doing this manually feels like a jig-saw puzzle with no good solution.
I’m used to my 3d printing workflow where I can simply press “arrange on bed”, and the software auto rotates and places my various objects. Does such a thing exist in the CAM world? If so, any recommendations?
I have no experience with this nesting software but it’s open source:
thanks, will check this out and report back. “nesting” was the word I was looking for!
Reporting back here. After trying a bunch of nesting software, the best I’ve found by far is this one:
https://webclient.nestingcenter.com/
no relation with them, but there are a few killer features for maslow :
  • Free, up to 50 pieces.
  • Can specify multiples of duplicate pieces to cut
  • Can define plywood size, and it will minimize number of sheets used (and maximize empty space on the last sheet)
  • Can specify distance from edge of worksurface to put parts (very helpful to avoid tipping over the edge!)
My workflow now looks like:
  • CAD in onshape
  • Create a drawing in onshape, with one copy of each cut, top down
  • nest using nestingcenter
  • CAM in Krabzcam
  • Import to maslow
Thank you for sharing
fyi Fusion360’s September 2024 update just added auto arrange feature.
Have used Fusion360’s auto arrange and deepnest.io before. Both were helpful.
Where’s the CAD-CAM software that @bar created and uses to visually design an abundance :slight_smile: of parametric things like this…
Does that CAD-CAM software have auto part layout too? Can’t find the tool URL, I understand it maybe Beta still, but wanted to try out again. Searched a following places, but couldn’t find a link…
https://maslowcreate.org ?
It does have an auto layout feature based on deep nest!
I’m not quite ready to launch it yet because as soon as I do I will get a whole bunch of questions and find a bunch of bugs to fix and I want to be able to give it the attention it deserves. Hopefully once all of the Kickstarter stuff is shipped out in the next week or so I should have time to focus on it.
