Serial Messages
Index.html Version: v1.25.0-24-g0bc73d4a-dirty
[MSG:INFO: FluidNC v1.25.0 (HEAD-0bc73d4a-dirty)]
[MSG:WARN: Previous boot ended in panic - attempting to load config anyway]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: tmc_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor1]
[MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:NO_PIN Disable:NO_PIN R:0.11]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: WebSocket send protection active (canSend() checks enabled)]
[MSG:INFO: Captive Portal Started]
Grbl 1.25 [FluidNC v1.25.0 (HEAD-0bc73d4a-dirty) (wifi) ‘$’ for help]
[MSG:INFO: ‘$H’|‘$X’ to unlock]
[MSG:ERR: Motor not found on Top Left]
[MSG:INFO: Current z-axis position loaded as: 8.680]
[MSG:INFO: TL encoder angle difference too large (-1642 counts), treating belt positions as stale]
[MSG:ERR: Maslow failed to initialize - fix errors and restart]
[MSG:INFO: Maslow update loop registered with hardware watchdog]
[MSG:INFO: Zm=8.680mm, Z home=3.680mm, Z position=5.000mm]
Remove cover (3 screws) from the control board, check the area around the IC near the Top Left cable for heat marks, shorts etc. confirm the heatsink is mounted on the IC. (@bar can you check this please.)
You say Maslow “4,” not 4.1. Before updating to 4.1, I had to apply hot glue around the connectors so the motors wouldn’t lose communication due to dust and frequency interference; the update fixed this.
I will DM you a code for a replacement control board right now. While that is on the way, check to make sure that there isn’t an issue with the wire going to the motor which is the other thing which can cause that fault.
It’s either an issue with the motor driver chip for that motor, or an issue with the wire connecting that motor to the board.
Thanks Bar, I got the replacement boards. Quick update: I swapped one in Monday and it ran fine at first, but tonight Top Left stopped retracting partway through Find Anchors. On Retract All, the other three belts reported “pulled tight” and TL never did. I swapped in the second board with the same motor and cable, and TL works fine, so the wire and motor seem good and it looks like the driver on that board.
