I have done a lot with trying to dial in my Maslow and would like to help but I am having trouble following what you are doing.
Have you read this Post by Bar to make sure you are measuring your benchmark correctly?
I think it would be easiest for us to help if we could visualize your results.
To start I would suggest you:
- Wipe EEPROM and delete your groundcontrol.ini
- Run the full calibration
- Post your groundcontrol.ini so we can see your values after a calibration
- If your groundcontrol.ini values look as to be expected then run a benchmark
- Post your benchmark results in a similar fashion as above
- We will suggest a change based on your values
- Copy groundcontrol.ini and name it groundcontrol.ini.bak
- Make changes suggested
- Run another benchmark and post for us to compare with the original benchmark
- If the results did not get better. Revert back to groundcontrol.ini.bak
- Repeat steps 6-10
