Only one Z axis motor is working
I’ve finally finished to assemble my Maslow 4.1.
I’ve updated firmware to 1.07 (index.html.gz and firmware.bin) and used the 1.06 maslow.yml file.
I’ve successfully retracted the belts which seems good but after playing with the Z axis buttons in the UI, only one stepper is working. The second one does nothing at all, which leads the router to be in diagonal.
Is there a way to test the Z motors ? Cable seems to be correctly plugged in.
Thanks for your help.
Console output:
Serial Messages
Index.html Version: 1.07
[MSG:INFO: FluidNC v0.87 (Maslow-Main-ec171155-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO:   Motor0]
[MSG:INFO:   Motor0]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.110]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:gpio.38 Disable:NO_PIN R:0.110]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
error:3
error:3
JogTo: '$J=G91F300Z-5
error:8 - Command requires idle state. Unlock machine?
Test
[MSG:INFO: Firmware Version: 0.87]
[MSG:INFO: I2C Timeout: ]
[MSG:INFO: 10]
[MSG:INFO: All tests passed on Top Left]
[MSG:INFO: All tests passed on Top Right]
[MSG:INFO: All tests passed on Bottom Left]
[MSG:INFO: All tests passed on Bottom Right]
JogTo: '$J=G91F300Z5
[MSG:INFO: Caution: Unlocked]
I have the same here, just exchanged the cables from one to the other motor, motors are ok but not the board…
Try swapping the stepper cables to the opposite ports. If the fault moves it is the board.
Unfortunately this seems like a very common issue with this batch of boards, I’ve just DMd you both a code for a free replacement. I’m sorry for the trouble!
Curious if root cause is understood? posted info/questions that may be related at
Edit:. Saw some posts about a batch of boards not being soldered/reflowed correctly. Saw some people having success fixing by reflowing or hot air gun. But am still curious about ENN pin mentioned in above post.
