I ordered a while back after the kickstarter was closed on the maslow website said estimated march. Any idea when these kits will arrive?
Today’s video answered this question ![]()
I’ve been told that we will have tracking numbers on Monday ![]()
I got my shipment this past week and finally getting it out together. What are the end pieces that you loop the belt and place it in it called? One of them has a much wider hole and the nut/bolt goes right threw and i am not able to connect the two sides together. Wanted to see if there were replacements i could order or get.
Belt End you should have been supplied 8 halves
Shop — Maslow.
Perfect thank you! Yes there were 8, one of the 8 had a bolt hole that was bigger than the others and the nut goes straight through.
I will send you a DM with a code for a free replacement for that ASAP!
