Thanks for the inputs. Its all starting to make sense now. I’m feeling much better about the direction I need to head in. Seeing how I am starting essentialy from scratch, I am going to give WC with Holey a go first.
there are a number of patches that have been made to the stock firmware and GC
code, but they cannot get to users unless there is a release.
We went a good while with releases every two weeks, and the announcment was to
move releases to a longer timeframe as there were fewer changes, but they just
stopped instead.
I have to check to see where in time the stock firmware is based upon (my build system checks out a particular sha) but I haven’t changed it for a while, so it’s old. There might be some “recent” changes in the stock firmware master branch that have not been incorporated into the holey branch of my firmware fork.
I’ve been playing with the Linux version of WC today. So far so good, I’m going to proceed with it. I really like the layout, it’s pretty intuitive. Also, there’s activity around it’s upkeep so that’s a bit reassuring.
I initially thought the same thing, but it is actually easier to start with webcontrol. if you use groundcontrol to calibrate your chains then you have to do the chain stretch… you can skip that with webcontrol.
I had the problem that my alloy top bar wasnt strong enough for the chain-length clibration. One motor got pulled out of position. I now want to replace it with an steel/iron top bar. My top bar is about 67cm / 26.5 inch over the working area. Is this enough to replace the 12" top bar with a 14" top bar?!
