1 file to set up many … making your experience better
Re published from here:
https://www.disciplesofcnc.com/wiki/pmwiki.php?n=Site.WinMaslowSetup
WinMaslowSetup
Single File setup for Windows 10
This process takes ~15 to 20 minutes on an old laptop. You must be connected to the internet for it to perform the download.
When run it sets up the following directories:
C:\maslow
C:\maslow\backup C:\maslow\designs C:\maslow\docs C:\maslow\extras C:\maslow\ground_control C:\maslow\temp
C:\maslow\ground_control\firmware C:\maslow\ground_control\program
it copies groundcontrol.ini from the user directory to - C:\maslow\ground_control\program
It then makes a backup of the program directory Next it makes a backup of the firmware directory
these go to the C:\maslow\backup directory
After that it deletes most of these files
Next it downloads a single file with ground control and firmware to the C:\maslow\temp directory
From there it installs the windows portable Ground Control and the Firmaware to there respective directories and deletes the files from the temp directory when setup is completed
You can launch Ground Control by navigating to this directory and double clicking Launch Ground Control.bat
or paste this line in a commandline
C:\maslow\ground_control\program\Launch Ground Control.bat
This is handy for making a copy of your system for troubleshooting by re-running the program a back up with your settings is made in the backup directory you can locate the files by time stamp.
The files can be found from the Shared Files link on the Members page at: *( an membership login is needed, accounts are free)
https://www.disciplesofcnc.com/mlp.html
Report any problems at our contact page:
https://www.disciplesofcnc.com/contact-us.html
We appreciate feedback.
