This is a companion discussion topic for the original entry at http://maslowcommunitygarden.org/Sled-With-Center-Alignment-Jig.html
Excellent, Not sure you posted this but that is perfect, and should really help with setup accuracy.
Thanks!!
I thought it was a great idea
Feel free to make any changes to the page!
Here’s a picture for those just viewing through the forums:
Wow, that would have saved me some time. Great idea @Stephen_Slagle
I can’t take all the credit, it was a collaborative design…
Kudos to all…
Can you measure and give me the exact dimensions of the Cut for you? Top to bottom / side to side? Is yours perfectly round?
@Bee I would, but that was done by Bar, not me… I do not yet own a Maslow… Soon, Very Soon, I hope
@Bar cay you help Bee out…
I’m off by 1/8th, 3.2 mm in the X axis in the upper left corner of the Maslow over 17.5 inches.
This is with 1 auto calibration run. Should I hold or fold?
What next?
Running the calibration test pattern again by clicking Actions -> Advanced -> Run triangular test pattern is a good place to start. It will continue to refine your measurements when it is run a second time
run the accuracy test, that gives a much better picture of the machine’s
accuracy than just the error in a circle.
