First some Background:
Some small ‘m’ maker friends and I invested in the Maslow 4.1 Kickstarter.
We had a busy year so we only assembled it a few months ago and very soon discovered we had one of the faulty boards that could’ve control one of the stepper motors.
This was swiftly sorted by Bar (for which many thanks).
Being in Australia the DeWalt router is not a sensible option and we have not yet invested in a spindle however Josh has machined a piece of aluminium into a workable pen holder.
We will move to a spindle if and when we have got the machine working reliably. We are dedicating our Wednesday afternoons to this.
To date we had successfully drawn the Maslow Doorsign that elsewhere was used to educate. And we had successfully drawn a line drawing (2D) of a WM graphic on an A3 sheet following Orob’s excellent guide to generating GCode from Inkscape.
Since then we have been unsuccessful at getting a 3D graphic drawn. (Note, by 3D I mean using layers in inkscape to create the various depths of cut but changing pen colours to represent them on paper.) For this the canvas was set to 1400 x 700 and a corresponding roll of paper was attached to the spoil board.
I am posting this because we need some help.
What follows is a log in the from of notes I made in progressively more detail as we struggled. While I do have some other serial logs but I shall attach the latest at the bottom.
Maslow issues
2026/08/19
Maslow stopped in the middle of a job.
Went through a series of turn off and turn it on again to no avail.
Eventually went home with all the belts still extended
At home I tried to retract belts.
No response.
Discovered that the “applied tension belt traction limit” was set at 300 and could not be reset from the quick menu. Went into configuration in Fluid NC and still see 300.
Try to reset to 1200
Response was:
“Set failed !Error 503: server not responding.”
The Setup button was greyed out and did nothing.
In Options > Apply tension belt limit and changes to belt Retraction Limit and Extend Distance just do not stick.
I was able to get the Maslow onto my WiFi which we had not been able to do at Josh’s. However I was not able to update to the new firmware.
At some intervening time I was able to retract the belts but I appear not to have made any notes.
2026/09/02
Back at Josh’s.
Manually updated firmware to 1.24.0
Replaced Index & YAML
Extended all, applied tension and the Maslow failed to attain Ready to Cut. Apparently still Taking Slack. Release Tension is the only green option. But ‘Maslow is not ready to move’ keeps coming up.
So
Power off, on and reload maslow.local.
Setup is available again.
We Retract all … : State Retracting. Release Tension is again the only green option.
So
Reload maslow.local
Power off, reload maslow.local.
Previous Serial log has vanished.
Setup not available
Reload
State:Retracted
Extend all
State: Extended
And because we were so frustrated we cycled through again
Retract all
State:Retracted
Extend all
State: Extending
So
Reload webpage
Setup provides choices.
Apply tension
State: Taking Slack
So
Reload webpage
State: Taking Slack
So
Reload webpage
State: Taking Slack
Apart from Stop the only button available is Release tension
Exploration occurs. Question; What is Belt retraction limit? (mm) If extend distance is 1200 could 300 be the issue? (NB conflation with current limit which in turn is elsewhere referred to as Retraction Force).
Changed it to 1000 in FluidNC Config Items.
Won’t save to YAML (Server not responding).
Reload.
Nowt
Reboot
Reload
Action button changed to red Alarm
Reload
State: Unknown
Action button still red Alarm but Setup is available.
Available options are Retract all, Extend all & Release tension.
Clicking Alarm changes button to Idle
State is still unknown.
(/Maslow_Apply_Tension_Belt_Retraction_Limit has saved to 1000 (which is within 200mm of /Maslow_Extend_Dist of 1200))
Release tension
State: Idle
Retract all
State:Retracting
Reload webpage
State: Taking Slack
So
Reload maslow.local
It doesn’t.
So
Stop and Reload maslow.local
It does.
State: Retracted and Setup is again available.
I’ve missed my volleyball in the park and my collaborator has gone for a meeting.
Shall I have one last try?
Can I even extend all the belts on my own?
Extend all
State: Extended
(Find anchor locations has become an option for the first time in a few sessions)
Apply Tension
State: Taking Slack
Only available (green) option is Release tension.
I try clicking Apply Tension again.
[MSG:INFO: Cannot take slack until belts have been extended] (which they had).
However the state is now Taking Slack.
I try clicking Find Anchor locations perhaps for a bit of sport.
[MSG:INFO: Cannot start Find Anchors until the belts have been extended] (which they are)
I try Stop
[MSG:INFO: Unable to determine machine position from belt lengths]
I decide to go home
[MSG:INFO: don’t you flipping dare]
I try release tension
[MSG:INFO: as above]
I rediscover a Restart FluidNC button.
State: Unknown
Action button Idle and Setup is available.
Retract all
State: Retracted
I pack up and go home.
State: Frustrated
Can anyone offer any suggestions or do we have a failure in the board?
Maslow-serial-26-09-02a.log (3.2 KB)
