First run very inaccurate
I finally got my Malsow4 working after months and a zillion hours of troubleshooting. I did my first test cut today of an 8” circle, while it looked like a circle, it was terribly inaccurate. My brief moment of elation was crushed. The g file was created in Fusion. The y axis was off by 1/8” and X as much as 1/4”. It has all the current updates and passed the calibration test. Appreciate any help trying to resolve this.
The first thing that I would recommend is just to run the anchor point finding again. It will build on the values that it found the first time and get a more accurate fix on where they are
Thanks, I ran Find Anchors three times. Checking it each time. The results are actually worse. It no longer looks like a circle. Y is off by a full 1/4”, X by 1/2”. This is on an 8” circle.
It might be worth deleting your maslow.yaml file entirely and starting fresh. I’m not sure what’s giong on, but I’m betting that it’s faster to start over than to figure it out.
Sadly that resulted in more problems. I deleted yaml and then calibrated. Seems like it was working. Ran my test, it locked after running and would not reconnect. Couldnt do anything. I cycle power and now I get Error:3. Still locked. Deleted Yaml again, restarted. Same. Will not accept any commands. See serial log on startup.
erial Messages
Index.html Version: 1.12
[MSG:INFO: FluidNC v1.13 (Maslow-Main-13c33c4c)]
[MSG:ERR: Cannot open configuration file:maslow.yaml]
[MSG:INFO: Using default configuration]
[MSG:WARN: Ignored key Maslow_tlX]
[MSG:WARN: Ignored key Maslow_tlY]
[MSG:WARN: Ignored key Maslow_trX]
[MSG:WARN: Ignored key Maslow_trY]
[MSG:WARN: Ignored key Maslow_blX]
[MSG:WARN: Ignored key Maslow_blY]
[MSG:WARN: Ignored key Maslow_brX]
[MSG:WARN: Ignored key Maslow_brY]
[MSG:WARN: Ignored key Maslow_tlZ]
[MSG:WARN: Ignored key Maslow_trZ]
[MSG:WARN: Ignored key Maslow_blZ]
[MSG:WARN: Ignored key Maslow_brZ]
[MSG:WARN: Ignored key dc_servo]
[MSG:WARN: Ignored key y]
[MSG:ERR: Skipping key max_rate_mm_per_min indent 4 this indent 2]
[MSG:ERR: Skipping key acceleration_mm_per_sec2 indent 4 this indent 2]
[MSG:ERR: Skipping key max_travel_mm indent 4 this indent 2]
[MSG:ERR: Skipping key homing indent 4 this indent 2]
[MSG:ERR: Skipping key cycle indent 6 this indent 2]
[MSG:WARN: Ignored key cs_pin]
[MSG:WARN: microsteps value 0 constrained to range (1,256)]
[MSG:INFO: Machine Default (Maslow S3 Board)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 6]
[MSG:INFO: Axis A (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Motor0]
[MSG:INFO: Connecting to STA SSID:Maine Island 2.4]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.11.146]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://maslow.local/\]
[MSG:INFO: SSDP Started]
[MSG:INFO: AutoUpdate: Checking for new release…]
[MSG:INFO: AutoUpdate: API HTTP Status: 200]
[MSG:INFO: AutoUpdate: Latest release: v1.13]
[MSG:INFO: AutoUpdate: Already running the latest version or newer (v1.13)]
Grbl 1.13 [FluidNC v1.13 (Maslow-Main-13c33c4c) (wifi) ‘$’ for help]
[MSG:INFO: ‘$H’|‘$X’ to unlock]
[MSG:ERR: MaslowKinematics not available]
[MSG:INFO: Current z-axis position loaded as: 0.000]
[MSG:INFO: loadBeltPositions() called]
[MSG:INFO: Validity check: ret=0 validityMarker=1]
[MSG:INFO: TL encoder moved 21 counts (-0.225mm) since save, adjusting position]
[MSG:INFO: TR encoder moved 0 counts (0.000mm) since save, adjusting position]
[MSG:INFO: BL encoder moved 13 counts (-0.140mm) since save, adjusting position]
[MSG:INFO: BR encoder moved -17 counts (0.183mm) since save, adjusting position]
[MSG:INFO: Belt position load: Set currentState directly to EXTENDEDOUT]
[MSG:INFO: Starting Maslow Version v1.13-6-g13c33c4c]
error:3
error:3
error:3
error:3
error:3
error:3
error:3
error:3
error:3
error:3
error:3
This looks like the same problem I had when running V1.13, Bar found some problems with the firmware. Try this version:
you can’t just delete the maslow.yaml, you need to upload the default one for
the version you are running. That may be fixed in the lastest that Bar uploaded
this weel.
i uploaded the latest yaml file. No change, so reloaded the latest firmware. That at least allowed me to recalibrate the machine. Now I am getting an error 22. on any attempt to jog. Sooooo frustrating.
please post your logs.
David lang
Soo, after yesterday’s frustration, I was about to trash the whole deal. Then I tried one more time this morning. It allowed me to recalibrate and it seemed to work. Test cut was off by an 1/8” but much better. Looked like a circle at least. I adjusted the x and y multipliers, which got it dialed in very close in y . X needed a little more adjustment. Tried another run, and it stopped in mid-process with an error on a G file that it has run successfully multiple times. One of the belts was now slack. Could not get it back to working, restarted, etc, starting to get error messages again. Can’t find belt length, etc. I suppose I can recalibrate again, but not sure there is a point if it will just repeat the problem. Does yours or anyone’s run reliably?
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting…]
[MSG:INFO: WiFi on]
Apply Tension
[MSG:INFO: Requesting state change from Unknown to Taking Slack]
[MSG:INFO: Cannot take slack until the belts have been extended]
Retract All
[MSG:INFO: Succeeded]
[MSG:INFO: Top Left pulled tight with offset -1.610]
[MSG:INFO: Bottom Right pulled tight with offset -1.739]
[MSG:INFO: Bottom Left pulled tight with offset -3.940]
[MSG:INFO: Top Right pulled tight with offset -19.733]
JogTo: '$J=G91F300Z0.0019685039370078744
JogTo: '$J=G91F300Z0.1
Maslow is not ready to move.
Could not perform Jog. Belt lengths are unknown.
Stevec wrote:
Date: Sun, 09 Nov 2025 16:57:11 +0000 Soo, after yesterday’s frustration, I
you do not need to recalibrate unless your frame changes or you manage to
corrupt the maslow.yaml file.
However, when it has a problem and stops, you do need to detach the belts,
retract them (so that the maslow knows where the ends are), then extend them,
connect them to the anchors, and hit apply tension.
it looks (from the logs below) that you tried doing apply tension, then when
that didn’t work, did a retract all, but with the belts attached to the anchors.
that makes it think that the belts are fully retracted when they are in fact
extended and attached to the anchors.
I wonder if adding some UI user logic as part of find anchor points to help clarify this. Ie a pop up like “ first time running find anchor points or frame size change or yaml change? Yes to continue.”
Dano
Thanks for your continued feedback. I am aware that recalibration should not be needed. But it is often the only way I can get the machine back in a responsive manner. My knees are aching from getting on the floor and detaching and reattaching. So I got it back up. Applied tension,started to jog and the lower left belt is now slack.
Serial Messages
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
Apply Tension
Retract All
Release Tension
[MSG:INFO: Requesting state change from Belts Retracted to Releasing Tension]
[MSG:INFO: Cannot release tension from state Belts Retracted]
Release Tension
Release Tension
Extend All
[MSG:INFO: Center coordinates updated in MaslowKinematics: X=1520.379 Y=1218.865]
Stop
Extend All
[MSG:INFO: Requesting state change from Extending Belts to Extending Belts]
[MSG:INFO: Cannot extend the belts until they have been retracted]
Stop
Retract All
[MSG:INFO: Requesting state change from Extending Belts to Retracting Belts]
[MSG:INFO: Bottom Right pulled tight with offset -1386.393]
[MSG:INFO: Bottom Left pulled tight with offset -1454.235]
[MSG:INFO: Top Left pulled tight with offset -1747.019]
[MSG:INFO: Top Right pulled tight with offset -2092.237]
Retract All
[MSG:INFO: Requesting state change from Belts Retracted to Retracting Belts]
[MSG:INFO: Top Right pulled tight with offset -0.129]
[MSG:INFO: Top Left pulled tight with offset -3.532]
[MSG:INFO: Bottom Left pulled tight with offset -0.043]
[MSG:INFO: Bottom Right pulled tight with offset -517.801]
[MSG:WARN: Low memory: 14716 bytes]
[MSG:WARN: Low memory: 12288 bytes]
Extend All
[MSG:INFO: All belts extended to 1960.000mm]
Apply Tension
[MSG:INFO: Requesting state change from Belts Extended to Taking Slack]
[MSG:INFO: Center point deviation: TL: 0.000 TR: 0.000 BL: -6.767 BR: -5.916]
[MSG:INFO: Center point deviation within 12.000mm, your coordinate system is accurate]
[MSG:INFO: Current machine position loaded as X: -39.695 Y: -54.776]
[MSG:INFO: Before update - mpos: X=nan Y=nan Z=0.170]
[MSG:INFO: Setting motor positions directly from measurements:]
[MSG:INFO: TL belt: 1802.006 TR belt: 1829.547]
[MSG:INFO: BL belt: 1723.657 BR belt: 1801.531]
[MSG:INFO: After update - mpos: X=-39.704 Y=-54.762 Z=0.170]
[MSG:INFO: Requesting state change from Taking Slack to Ready To Cut]
Release Tension
[MSG:INFO: Requesting state change from Ready To Cut to Releasing Tension]
[MSG:INFO: Requesting state change from Releasing Tension to Belts Extended]
[MSG:WARN: Low memory: 12192 bytes]
Apply Tension
[MSG:INFO: Center point deviation: TL: 0.000 TR: -0.000 BL: -4.035 BR: -5.724]
[MSG:INFO: Current machine position loaded as X: -40.873 Y: -54.098]
[MSG:INFO: Before update - mpos: X=-39.704 Y=-54.762 Z=0.170]
[MSG:INFO: TL belt: 1800.672 TR belt: 1830.030]
[MSG:INFO: BL belt: 1725.882 BR belt: 1803.072]
[MSG:INFO: After update - mpos: X=-40.870 Y=-54.085 Z=0.170]
JogTo: '$J=G91F2500X0.5
JogTo: '$J=G91F2500X1
JogTo: '$J=G91F2500X1Y-1
JogTo: '$J=G91F98.43X1
JogTo: '$J=G91F98.43X-1
Apply Tension
[MSG:INFO: Requesting state change from Ready To Cut to Taking Slack]
Apply Tension
Apply Tension
This is 100% the same issue that I saw. Good call @ian_ab
This error message is coming from the computer side, I think that just refreshing the page should fix it.
Is it slack all the time or just on some parts of the sheet?
It is slack when moving away from the anchor. It’s like the motor is putting out more belt than needed. It retracts properly. So there is not a problem when moving toward the anchor. The other 3 belts behave properly.
to further clarify. I becomes significantly more slack as it gets to middle and beyond. I can pull at least 6” to 12” off the reel.
Wow yeah that is super slack. That sounds like there might be something more wrong than just a calibration issue to have that much slack. Does it stay tight anywhere on the work area?
i recalibrated again, seemed better but lost communication while/after running my test g code.I had to restart to get it to connect again. Now its in unresponsive to any commands..
[MSG:INFO: Caution: Unlocked]
Calibrate
[MSG:INFO: Requesting state change from Unknown to Calibrating]
[MSG:INFO: Cannot start calibration until the belts have been extended]
Release Tension
Release Tension
Extend All
Does refreshing the page clear that?
I feel I am getting closer. The accuracy is within 1/16” without tweaking but I still have the problem with the slack belt from the same lower left spool. Definitely worst the farther from the anchor. It is definitely letting out too much belt while traveling. I can release tension then apply tension and it takes up the slack temporarily. Can this be fixed?
