I’ve made my frame per the instructions for the 2021 M2. It said to mount the bottom of the top bar bracket 10” above the waste board when I did that the co-plainer distance is only 16-1/8”. Not 18”. The attached pic shows how I measured it. Is this the correct way to measure? Do I now need to raise the top bar 1-7/8” ?
@MacAleese do you have any suggestions?
well since I have heard anything on my issue, I went ahead and moved the top bar up higher and recalibrated again and it seems to be running more true to the dimensions that the file lists. I wish the instructions would have been better to make sure I got the 18" above the waste board but I figured out how much to raise it to get the final co-planer dimenstion.
