(comments out of order)
Have you done anything like this in the development of the Maslow?
No, there have been no tests like this in the past. When Bar developed the
Maslow he had a much simpler model in mind, the community has added many things
he didn’t think of at the time, and Chain Sag and Tilt are the two most recent
Chain Sag experiments. Thinking that if you put the sled at 0,0 about,
(center of board), and took the bricks off. Assuming that the motors paid out
the equal amount of chain on both sides that would put the sled at 0,0 (I
would eliminate the current chain sag corrections from the program for this
experiment.) without any sag corrections, it would sit somewhere above the 0,0
point on the y, and hopefully ok on the x since both chains should be the same
length.With the bricks removed, the sled assembly with the router weighs “x”, say 7
pounds for discussion. With your new optical measuring cameras, is there a
way to lock in on that point, and then record the sled movements as weight is
added to the sled up to the brick weights, or even more for the experiment.
The optical tracking should be able to see a difference.
I would not expect much difference at the top of the board, and more at the
bottom.
They can even do this test in the bottom corners, to see how much a variation in
weight between the ~min 10 pounds to something overly heavy like 30 pounds
affects the location.
One problem is that we don’t really know how heavy the sled is (and it actually
varies depending on how much vaccuum hose it’s lifting)
It’s impossible to get the sag to zero, but what we are trying to do is to
figure out of our calculation can properly model the sag.
) were confused and just voted on the Ground Control PR. For some reason I had it in my head that the firmware PR was just an earlier version of the GC pr which had been closed. I reverted the firmware version while awaiting the results of the GC PR and will do something when that vote is up…so get out there and VOTE folks!
