Good Morning - we have used both a MacBook Pro and a Windows laptop in an attempt to calibrate our Maslow.
Unfortunately, it gets as far as “Cut Test Pattern” and locks the screen.
We have tried both 1.09 and 1.08 with the Arduino running 1.09 Firmware.
This is a screenshot …
Good morning!
Bar identified an issue with the calibration sequence, discussed here, with a potential fix for Windows here.
If you need a Mac version instead, let me know, I can get one out to you.
Sorry, I have a new issue with the calibration. I am using the “bolt together frame”. Just to be clear; I wiped the EEProm and started from fresh. Whether I choose top or bottom feed from the script, The Chain method of measuring center to center gives me a -321 mm measurement. My actual measurement from the tape is 3016.25 mm. Of course this mucks up the chain calibration etc. One more thing, I am using the Triangular method of suspension.
Are you starting with the first link of the left chain on the top tooth of the left motor, hanging down off the left side of that sprocket? Top- or bottom-feed, both need to ‘Extend’ the chain from the left motor across to the right motor then ‘Pull it tight’ before clicking ‘Measure’. Apologies if that’s what you’re doing, it seemed like a way that a negative value could occur.
