I was really looking forward to an easy calibration procedure…but here we are.
I finished assembling my Maslow 4 today, turned it on, then upgraded the firmware to V0.81.
I retracted the belts, extended the belts, Put it on he frame, and ran the calibration procedure. If I remember correctly, nothing happened and the I didn’t realize the serial area was giving me messages because it was in the background.
Suggestion #1, put the serial messages on the same window as the calibration window.
Suggestion #2 - The calibration menu extends to the top and bottom of the screen on my computer, which makes it look like I’m missing stuff. Please put it in a box where you can see that it is one widow and doesn’t extend of the screen.
Suggestion#3 - When I finally saw the serial area was giving me messages, I couldn’t tell what was the last message. Please add date stamps or some way to know what the last message was.
I turned it off and on again and it told me I needed to go through the whole procedure again. I took it down retracted, extended, calibrate. Nothing happened…but this time I see it is telling me it needs to reboot.
After I reboot…it tells me I have to go through the procedure again.
I take it down, retract, extend, put it back up, calibrate…Everything retracts…but now it says the center numbers don’t line up because I’m off by 100mm. I look in the configuration screen and it is back to defaults. I change the numbers, but now it tells me it doesn’t know where it is, so I have to do the whole procedure again.
I take it down, retract, extend, put it back up, check the numbers, calibrate…Everything retracts…but now it says the center numbers don’t line up because I’m off by 100mm. That’s a 4" window. That’s not a lot of wiggle room. The instructions say “These measurements are just a rough guess to get the calibration process started”, but apparently they really do matter.
Suggestion #4…Don’t say it only needs to be rough when the tolerance is in inches.
I make more accurate measurements, update the machine numbers with the more accurate numbers. And it tells me I have to go through the whole procedure.
Suggestion #5…I understand that it won’t move because it thinks its not safe. But if I can see that it’s roughly in the center…just have it tell me what the numbers should be so I can enter those numbers and let it to it’s thing.
I try at least 4 more times of taking it down retracting, extending, calibrate and more times than not it does nothing with some cryptic measurements, or it says that the center is not good enough, even though I’ve checked the measurements six times now.
At this point, I give up and am going back to the original maslow. I wish I hadn’t of modified the bottom part of my frame until I made sure that this worked.
I remember that he OG maslow procedure was initially confusing, but I could at least work through it. I had high hopes for this automated calibration procedure, but more automation means there’s less I can do and the I could never figure which of the many error messages was holding me back.
Suggestion number 6 - The thing I was looking forward most was not resetting chains. But, based on my experience, I just have more chains to reset, which makes it more tedious. Why won’t it just remember where it was? Why do I have to reset everything every single time?
Also, my browser kept saying I timed out as I removed and put the Maslow on the frame.
I tried to attach my error logs, but that feature seems to be missing
Here was the last one before I gave up.
Serial Messages
Index.html Version: 0.81
[MSG:INFO: FluidNC v0.80 (Maslow-Main-061f8600-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
[MSG:ERR: Cannot run calibration until all axis are extended fully]
[MSG:ERR: Please press Retract All before using Extend All]
[MSG:INFO: Set to comply]
[MSG:INFO: Top Left pulled tight with offset 36.288]
[MSG:INFO: Bottom Right pulled tight with offset -1290.424]
[MSG:INFO: Bottom Left pulled tight with offset -1486.937]
[MSG:INFO: Top Right pulled tight with offset -1640.001]
[MSG:INFO: Top Right pulled tight with offset -0.075]
[MSG:INFO: Bottom Left pulled tight with offset -0.011]
[MSG:INFO: Bottom Right pulled tight with offset -211.125]
[MSG:INFO: Top Left pulled tight with offset -1677.298]
[MSG:ERR: Unable to move safely, stopping calibration]
