Calibration failure M4.1 V0.88
Hi Bar,
I´m trying to calibrate my updated Maslow 4.1.
I installed firmware V0.88 but it seems that the calibration process is stalling, it keeps computing or reading fitness points but I get a repeated warning about the value’s being to low.
See logfile In the attachment and screenshot of config
What am I doing wrong?
Appreciate the help!
Maslow-serial-3.log (109.5 KB)
Aloha,
that’s how the new calibration process works; I was quite sure something was wrong when my new calibration exhibited that behavior. When I restarted and just let it run, it eventually found solutions at every calculation point that were more than satisfactory.
Mahalo,
@MrN808 is right that the new calibration process will retry several time to get a good answer, but from looking at your log I’m seeing that it’s never finding a good answer.
Some folks have reported that uploading a new Maslow.yaml file has fixed weird issues with the new system for them, can you give that a try? I’d recommend downloading your old one first so you have a backup just in case you want it back.
Thanks for your replies!
@ Bar I’ll try replacing the yaml file.
By the way, the Maslow stops moving after 4 or 5 point ( of the 9x9 grid). I killed the power after approximately 10 min …
Uploading new yaml file worked! The Maslow fully calibrated.
But I´m running into other problems, I will post in the right section…
