Hi all,
I am trying to use my Maslow4 (original kickstarter edition), but am running into some trouble.
First some basic info. My setup is on my (slightly bumpy) attic floor:
It is connected to a dedicated Wifi router nearby. UTP cable connectors glued in place.
Actual anchor dimensions (mm):
TL-TR: 4208
BL-BR: 4212
TL-BL: 3512
TR-BR: 3512
TL-BR: 5485
TR-BL: 5473
So not perfect, but I assume good enough to do some cutting. Spoilerboard is some 18mm particle board I had laying around, approx. 1800x1000mm.
Steps:
- Installed the latest firmware (0.87), including a fresh new maslow.yaml (5.3 KB) and index html file.
- Reboot. Moved Z axis all the way down (no bit in the router).
- Config → set dimensions & calibration grid 1500x800
- Retract all. BR did not move. After other 3 were retracted, did a 2nd retract all and that retracted BR as well.
- Extend all. Bottom belts extended 278cm, top belts 258cm (!)
- Calibrated succesfully (Maslow-serial.log (14.4 KB), fittnes 0.73)
- Released tension, had some dinner and went back a little while later.
- Applied tension. This actually released tension and triggered an error:
Calibration complete
Calibration values:
Fitness: 0.7325433634538072
Maslow_tlX: -3.9
Maslow_tlY: 3516.4
Maslow_trX: 4190.5
Maslow_trY: 3511.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 4193.5
Maslow_brY: 0.0
A command to save these values has been successfully sent for you. Please check for any error messages.
CLICKED “APPLY TENSION”
[MSG:INFO: Set to comply]
[MSG:ERR: Unable to move safely, stopping calibration]
- Did a powercycle, retract all, extend all, apply tension. Log shows warnings:
Serial Messages
Index.html Version: 0.87
[MSG:INFO: Caution: Unlocked]
[MSG:ERR: Cannot take slack until all axis are extended fully]
[MSG:ERR: Please press Retract All before using Extend All]
[MSG:INFO: Top Right pulled tight with offset -2582.522]
[MSG:INFO: Top Left pulled tight with offset -2584.154]
[MSG:INFO: Bottom Right pulled tight with offset -2599.324]
[MSG:INFO: Bottom Left pulled tight with offset -2587.944]
[MSG:INFO: Center point deviation: TL: -0.011 TR: 0.354 BL: -12.589 BR: 2.835]
[MSG:ERR: Center point deviation over 12.000mm, your coordinate system is not accurate, maybe try running calibration again?]
- Tried to jog, no movement but log shows “Jog: X-100”. Jog Z works fine.
- Tried running the maslow logo gcode. No movement, and got warnings (see below). After which maslow disconnected.
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 140.797mm Counter: 1]
[MSG:WARN: Previous error was 140.797mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -137.954mm Counter: 1]
[MSG:WARN: Previous error was -137.954mm]
[MSG:INFO: Tool No: 0]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 140.797mm Counter: 2]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -137.954mm Counter: 2]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 140.797mm Counter: 3]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -137.954mm Counter: 3]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 140.797mm Counter: 4]
[MSG:WAR[GC:G0 G54 G17 G20 G90 G94 M5 M9 T0 F0 S0]
- Power cycled & calibrated again. After measuring a few waypoints error was triggered:
MSG:ERR: Calibration data not acknowledged by computer, resending]. Full log: Maslow-serial (errors during calibration).log (18.8 KB)
Before continuing I am curious if anyone has had these issues as well?
Thanks for reading all the way to the end and a happy new year to everyone!
