I’m new to this forum and trying to run my router with a file created by vcarve and saved gcode using the easel post processor but keep running into a undefined feed rate error which will not move my Z. The x/y move just fine however. Any help would be appreciated.
That line has a feed rate of zero, infinite move time is probably an error. Maybe check your vcarve feeds and speeds? Post processor bug?
Is there a better post processor to use for vcarve? I am showing a feed rate of 250 mm/min
I don’t use vcarve, not in my budget, but see if there’s a grbl post
You could manually change that 0.0 to a higher speed
I’d call that a bug in their post, somebody mistyped a variable name is my guess
