To test MaslowCNC, I used MakerCAM by drawing a straight line from the origin out to 10cm. When I imported it into Maslow the line was up 100 (mm?).
Original G-code
(Generated by PartKam Version 0.05)
G21 G90 G40
(follow path 1)
G0 Z15
T0 M6
G17
M3
G0 X0 Y0
G1 Z-0.1 F800
G1 X100 Y0 F1500
G0 Z15
M5
M30
I manually edited the gcode by changing Y0 to Y-100. This moved the line down to the origin.
Edited G-code
G21 G90 G40
(follow path 1)
G0 Z15
T0 M6
G17
M3
G0 X0 Y-100
G1 Z-0.1 F800
G1 X100 Y-100 F1500
G0 Z15
M5
M30
When I was working in inches it was even worse.
Imperial G-code
G20 G90 G40
(follow path 1)
G0 Z0.5905511811023623
T0 M6
G17
M3
G0 X0 Y0
G1 Z-0.003937007874015749 F800
G1 X4 Y0 F59.05511811023622
M5
M30
