(UPDATE- SOLVED!) HELP! Vertical Lines not cutting correctly
The depth of this first cut was about .25 inch. More of a test run than an actual cut for that one. when I noticed the issue, I came up to about 0.1in just to etch and see if the issue kept happening.
Looks like I just got it running correctly (turns out I needed more weight on the sled) , but I’ll be sure to upload a video of my first full cut!
adding more weight to the sled could cause you problems cutting across the top
(especially near the center), try doing a horizontal cut at the top of the
workpiece and make sure it still works there.
