Upload GCode button not working
It’s been a long winter without any maslow action, but I am trying to get back into it. Some amazing changes since I played with it last! Thanks for all the hard work!
Unfotunately I am having a problem with the latest firmware. It all worked once, but now I can’t upload any more code. The “upload gcode” button doesn’t do anything when I click it. I have tried both firefox and chrome. I can’t seem to use the “upload” button under the “sd files” section either.
Has anybody else had this issue?
I have seen that happen if you are connected to the machine via the popup which opens automatically when you connect to the “maslow” wifi network. Is that what you are seeing?
That popup that open automatically is extra restricted by the browser and usually doesn’t permit file uploads
Well interesting.. it wasn’t the same problem you were experiencing, but you pointed me into the right direction for the fix :upside_down_face:
I went looking for the ipaddress under “preferences” and noticed the “enable lock interface”. Once I unchecked that it all works fine.
Thanks for the quick reply!
Thanks! I had this exact same issue today. “Lock interface” was checked for some reason. Could be a bug? I’m on 1.23
