Hi !
I do not perfectly understand the visual of this view.
The home position is always on the center ( while a define home on lower left in “real” )…
And someone understande the big green rectangular totaly out of scope ?
Hi !
where did you get that colored background?
In the browser
Maslow web page. Clicking in the screen give me different view.
I was wondering the same thing. Maybe the area is supposed to be the calibrated area but in the wrong location.
Yep, clicking successively will cycle between them. The rectangle is NOT the machine bounds from maslow, but the code seems to indicate it is, so I wonder if we are not reporting the machine bounds correctly to this widget in the code. My anchors are in essentially a square and I get a large landscape rectangle too.
From the code, the 4 camera angles are: (click the image to cycle between them)
All but 1 and 3 seem like they are not really correct in terms of the view area and of the machine bounds. I’ve entered a github issue so we don’t lose it.
My views are also cut off on the bottom - usually I can only see part of my design. I haven’t figured out any way to zoom or pan that view.
same. If I end up being the one to take on the issue, I think that whole view could do with a revamp…
The box is supposed to be the size of a 4x8 sheet of plywood but I think that there is a bug with how it handles loading the home position. That rectangle should always be centered
