Mark Thomas wrote:
David, thanks for the information. Frame size is 2958mm x 1472mm, work piece
is a standard 4’ x 8’ piece of 3/4" plywood. I assume Green is good, white is
caution, and red is no go? My question on this would be why would there be a
no-go section on this machine at all? @bar can you comment on this?
the different colors are just different types of errors.
Red is the area where the two adjacent arms are both hitting the verticals of
the sled (top center, both arms are jammed against the side brackets as they
try to get more horizontal)
white is where the two adjacent corners are both hitting the verticals (towards
teh top left, it means that the top right and bottom left will both be hitting
the verticals, when they really want to be pointing more towards the bottom
right corner)
as you get into these areas, the arms that are hitting the verticals become
shorter than the machine thinks they are. Instead of the belt + arm being
directly in line with each other, they are at an angle, and the more they are
angled, the shorter the distance from the center of the bit to the anchor.
you can go a little bit into the white/red area, but it’s not a linear
relationship, going in say 100mm may produce 1mm error in belt length, but going
in 200mm may produce 10mm error in belt length (faked up numbers as an example)
if you are limited in your height, play around with that page setting your frame
to be narrower, that will get you a larger usable curring area
Z-Height of the anchors is 27mm. This is measured from the surface of the frame that the anchor is attached to, to where the belt end sits.
what matters is the distance from the center of the belt at the anchor to the
center of the belt at the arm. The default Maslow_*Z values in the .yaml file
assume that you have the anchors directly on the frame with a 19mm wasteboard
and a 19mm workpiece.
since you are moving the anchors up on the Z axis by 27mm, you will want to
reduce all four of these numbers by 27mm from stock
that said, I would not expect that to be the cause of pulling away.
I’m not really experiencing any pulling away of the sled anymore ever since I
fixed the frame and my angle is now 25 degrees measured from vertical.
the weight is holding it flatter.
No video to show, but what I can tell you is that the G-Code file I generated
is based on the home position of the Maslow being dead center to a 4’ x 8’
sheet of plywood (I also generated the .svg file to show my project having the
origin at the center of a 4’ x 8’ sheet of plywood). When I upload the g-code
and run the file, things run fine until it gets towards the top of the
workpiece, then it stops moving upwards vertically but you can clearly see
slack forming within the belt dials, particularly in from the belt anchored to
the bottom left (presumably the bottom right also). The machine then shuts
down and waits for me to basically perform a hard reset. My assumption here is
that, although I have designed the .svg and the g-code in such a way that
everything should be centered around the middle of a 4’ x 8’ piece of plywood
(and therefore everything was positioned within this boundary accordingly) the
physical setup does not reflect what has been designed on the computer, and
the Maslow is more vertically upward initially than being actually centered to
my workpiece, thereby going too “high” and running our of vertical “room” if
this makes sense. By moving the initial position of the Maslow down
approximately 5", I was able to run a test profile no problem in its entirety
without the issue presenting itself, lending to my belief that the Maslow is
going to high relative to the physical setup, coming to a conclusion that my
Maslow may not be centered to the workpiece but IS centered to the frame.
excess slack probably is caused by the Z values not being correct. I would
expect that you would be running into current limits towards the top center.
This was the reasoning for my asking about how is “home” defined after
calibration, as it sounds like it is centered to the frame and not to the
workpiece, since the workpiece parameters are not input anywhere that the
software and the Maslow would know is too far.
the maslow does not have any software ‘you are moving off where I think the
workpiece is, shutdown’ limits, just mechanical "I can’t move any further, I’m
pulling but not moving’ limits.
