If my Maslow cuts all areas of a 4’x8’ sheet, does the frame take up 5’x 9’, 6’x10’…?
Please see this thread:
Thank you so much!
the frame needs to be at least a couple feet longer than what you are going to
cut (4 ft longer is probably better than the stock 2 ft longer)
it will be ~2.5-3 ft taller than the width of what you are cutting
it will be 2-3 ft deep (depending on how you mount the legs, if you put anything
else on the frame, etc)
Thank you.
Did you mean “…than the height…”?
well, you talk about a sheet of plywood being 4’ wide, and 3/4" tall/thick
so for 4’ wide plywood, the machine is 6.5-7’ tall
