I’m experimenting with different feeds and speeds. And I think everything looks good, but I’m not sure if there are any warning signs I should be on the lookout for.
Is the sound while cutting a good indication of if things are set up well?
Here’s a short clip of a 1/8" bit cutting 1/4" deep on 1/4" plywood, I think this was at 50"/min, but was probably much slower because it was a bunch of small cuts.
It’s definitely louder than when it was cutting slower or doing more passes. Is that a good or bad thing, or does it not matter?
It’s always a little hard to get a real sense of the sound on video, but overall I think that’s great.
I was messaging with a friend recently and we were talking about the idea of integrating a microphone into the controller to measure the sound as a way for the machine to better self detect issues because it is a good way to measure how things are working.
In general should it be “loud, but not too loud” ? Like, it’s doing work but not struggling? Are there sounds I should look out for? Are there available pins on the existing board? It seems like a microphone would be pretty easy to add. And if it was a standard piece in a standard location, then comparing clips would be much easier.
Also, could this be the chips? I pulled this out of my dust separator after the cuts were done.
