That’s a good point. The belt I tested is of unknown origin and was what I had lying around to prepare the test setup. I’m not sure it’s actually Kevlar. I will repeat the test with new belts of known origin.
100%. This is why I’m keen on using actual Gates belts since they seem like they are the top tier manufacturer. Pretty sure they came up with this type of drive belt.
The 6mm and 9mm sections arrived today, so I should be able to test them soon with my janky setup.
Yes, I think converting belt length to cartesian is far more tricky. All we need to know is the stretch/elongation of the material and the force. The latter is what might be a little tricky because it changes based on belt angle and frame angle (among a few other things) as I mentioned in the original post and as @dlang also called out. Belt angle and frame angle are likely a good place to start trying to figure out how the force varies.
Lais wrote:
Yeah, without directly measuring belt tension, implementing any correction
model would be tricky. In theory, if you know the belt’s elastic constant, you
could correlate motor current to tension with some calibration, but I’m not
sure the constant is consistent enough between batches or over time to make
that practical. Either way, minimizing error at the source by using stiffer
belts is definitely a path that should be explored.
I also think that we can have a ‘belt stretch factor’ that can be tweaked by the
user to find tune it’
Absolutely. Especially since the M4 is out in the world with these steel belts, this would be great if someone wanted to upgrade to the nice Gates belt.
It will also be interesting to see if less stretch in the belts adds more stress on the arms or other plastic components.
Dano
Awesome work here!!!
I suggest figuring in the belt spool issue into your calculations. Remember that the motor current that we use for pull control does not directly go to line tension. You get less pounds of pull per Amp at short extension and more at long extension. That’s an easy calculation, and its something we should really be rolling into the code… There’s going to be a double whammy on this one, in that long exposed belts are stretchy, and the short belt pulls harder!
There’s also a squish factor for the belt wrapped on the drum, but wrapping at relatively constant tension will minimize this.
There’s a lot of value in rolling the drum fill radius (think layers of belt) into things so that we can specify -tension- rather than motor torque. As a really rough SWAG, the tension vs amps is likely varying 15% or so (assuming 3" empty drum and 3.5" full drum). Feels like a big factor if we are unhappy with and actively chasing 6% errors.
A really valuable test would be to set up horizontally with two anchors at useful spacing, then travel the unit between the two extremes. Data is line tension and actual position vs commanded position and tension setting. This will check a combination of the belt stretch and amps/tension/spool fill. Note that the return journey will likely look a bit different; the last motor to move (with its own drum fill diameter) will be the one that controls tension.
Another way to get at this would be to hang one vertically and take data on commanded position, actual position, belt tension (will be constant), and the tension setting required to move up.
I wish I had the time to dig into this!
FYI, doubling the belt width will cut the deflection in half.
harder!
it will pull harder for the same amount of current, but we don’t know how much
friction there is in the spool turning before any force is applied to the belt.
This is why I keep saying we have no way to measure tension, only length.
but we are not wrapping at constant tension, the tension will depend on how hard
you are pulling vs how fast you are moving, so when you are cutting with a dull
bit, you are wrapping under more tension than if you are moving with the bit out
of the wood.
we are chasing length small percentage length errors, I think the tension
differences are much larger
tension.Another way to get at this would be to hang one vertically and take data on
tension setting required to move up.I wish I had the time to dig into this!
it is a very interesting rabbit hole to go down
yep, but they would no longer fit between the top and bottom of the router. We
would have to use a longer spindle.
Got around to testing the Gates belts, and they are much worse unfortunately. They are far thinner so I wonder if that’s part of the problem.
@Lais Do you have any idea what belts you tested? Those seemed to be far superior. I’d love to test the same ones with my janky setup to see how they perform with the same process.
Note: I ordered a 100mm section, and had to test slightly less than 100mm and adjusted in the spreadsheet.
Thickness comparison – a little hard to tell in the picture, but they are quite different.
I might be the only one. But I’m having trouble understanding your data table.
I’m reading that it took 5kg for 1mm, 2.75kg for 1 mm, and 4.25 for 1 mm stretch. Is that accurate?
How do you determine the percentage numbers?
And the numbers under the force column (100, 90, 88) throw me off, what are those?
Just trying to understand your research.
Fair question – I stretched a length of belt by 1mm at a time and noted the force required to stretch it that amount. The 100, 90, and 88 were the total length of belt measured. Since the Gates ones were kinda pricy I just ordered a 100mm length and had to measure less than that due to attaching the anchors. (they actually gave me a little more than 100mm)
The percentages are how much the belt stretches per kilo of force. So 1mm stretch / 5kg force / 100mm length = 0.2% stretch per kilo.
Make sense? I should have added units/description to the length tested…
I received the Maslow belt from @bar and also got some from Gates for comparison. I ran some quick preliminary tests, and here are the results:
Tests 1 to 3: Original Maslow steel-reinforced belts
Tests 4 to 6: Gates PowerGrip GT3 belts
As @kyleschoen already found out, the Gates belts perform significantly worse.
From my measurements, the Maslow belts stretch by about 1% for every 340 N of force.
I’ll improve my setup this weekend to get cleaner results, but I don’t expect the values to change significantly.
I’m not sure what those first belts were, and unfortunately, I don’t have any leftovers to check. But the Gates belt I tested showed very similar performance — around 1% stretch at 170 N. I’ll double-check my setup this weekend to make sure the values are accurate.
This is super super valuable information!
Right now the best belt that we’ve tested is the default one, right?
Yes. The best belts I tested until now are the default ones delivered in the Maslow kit.
BTW, I mistakenly implied above that the Maslow’s ratio of encoder to belt varied with fill factor. It does NOT. The encoder reads the belt directly.
The ratio of belt tension to torque, however, DOES vary.
Sorry I’ve been MIA guys, but I have a good excuse: my first child was born three weeks ago!
Would love to resurrect this work though. Looking back at my calculations and trying to think how we could operationalize the data. I think we basically need 3 things:
- Estimated force on the belts
- An applied force coefficient
- A stretch coefficient
Estimating the force gets a little strange with a vertical frame, but roughly the top belts see an extra 4.5kg due to the weight on my setup which is ends up about double what the bottom belts see at the origin. So if we assume about 9kg for the top belts, and 4.5 for the bottom we’ll probably be pretty close. (Maybe someone can measure a horizontal setup?)
The coefficients that I came up with were as follows:
So we have:
- Estimated force: 9kg for top, and 4.5kg for bottom at the origin (vert frame)
- An applied force coefficient: 0.00375 kg per mm traveled
- A stretch coefficient: 0.002 percent per kg of force (direction traveled)
@bar is this something we can build into the software to test? Settings to fiddle with the numbers would be super cool. I think it’ll get us pretty darn close.
First and foremost…CONGRATULATIONS!!
Yes, I think that is absolutely something that we could add.
To make sure that I understand right, which direction is that per mm traveled in?
We probably need to factor in a bit of belt spool fill factor too, if we are getting down to this level of precision.
The drum is 91.1mm on the base wrap and 126mm at the outside. 1.4mm/layer of belt.
If we set “full” as the reference belt tension vs motor torque, at the drum you have 38% more belt tension for the same motor torque. Not too bad…
Assuming that 9 kg of pull is a reasonable belt tension on the core, that translates to 0.06 Nm of spool torque. Keeping that constant we see this variation. Clearly, we are planning to have a bit of belt above the spool radius, as my machine happily gives me 2,200mm of belt!
| Wraps | Pull radius | N | kg | Belt extension | Belt/wrap |
| 0 | 45.5 | 0.9 | 9.0 | 2,023 | 285.9 |
| 1 | 46.9 | 0.9 | 8.8 | 1,737 | 294.7 |
| 2 | 49.7 | 0.8 | 8.3 | 1,443 | 312.3 |
| 3 | 53.9 | 0.8 | 7.6 | 1,130 | 338.7 |
| 4 | 59.5 | 0.7 | 6.9 | 792 | 373.8 |
| 5 | 66.5 | 0.6 | 6.2 | 418 | 417.8 |
Happy early father’s day Kyle!
Dano
