the steppers are 200 steps/rev and the pitch of the lead screws is very precise,
it should not be neccessary to tweak the settings about how far it moves with
each step (this is in the maslow.yaml I believe, can you post that?)
Surely if the bit is slipping the depth would be less.
The force of the maslow moving the bit down would push it up into the collet and so result in a shallower cut.
I’m seeing the opposite of that - it’s deeper.
No, I’ve mostly seen it slip out from the router (even when using stright bits,
let alone upcut buts), making the cut deeper.
The gcode is telling the machine to move down 3mm so it makes sense that the whole ends up being 3mm deep. To me this sounds like an issue on the CAM software side, I don’t think it’s an issue with the Maslow z-axis
