Hi I use the z axis that comes with the standard kit back in June. I have the Rigid router and the pitch is the default setting for ground control. 3.13 I think.
Anyway if I set the zero exactly 0.125 above work piece it works properly, which doesn’t make sense to me.
It could be your setup. I have seen on my machine that the “regular” first generation z-axis was pulled in by the bit. The slop I had in the z-axis allowed that to happen. Now I am using the 3D-printed router base and the z-axis is very reliable.
the pitch to the router is about 3mm. (1/8)" so that means you have enough slop to turn the shaft 360 degrees before it actually starts moving. one the of the threads above talks about adding extra shims to reduce this issue.
Some people live with it and just modify the design they are cutting for it to come out correct,
others will modify the router so it’s more percise, just really depends on what is easier or you.
I used downcutting bits and crosscutting bits. Since the z-axis in the original configuration has some slop due to the connector with the orange spring thing to the screw as well as the movement of the screw itself, the bit was pulled towards the board when cutting. This was quite significant in my case, more than 1/8" in total. I couldn’t get reproducible z-height with that setup.
Now I am using the 3D-printed router holder and everything is pretty accurate. Fantastic upgrade.
Check out this link.
Works like a charm, although it takes a little to get it printed and setup.
