Just tried recalibrating again after modifying the frame (again) to get a significantly larger distance between the anchor points.
And also after swapping over to using the M4 Router Mounter Be-Gone
And changing to firmware version 0.74 from Release v0.74 · BarbourSmith/FluidNC (github.com)
Calibration went well, although I had one observation that I’ll drop into a different thread.
However, after (and probably during) calibration the Z-axis motors would not move at all, although the PCB fan would come on to show that the PCB at least was thinking about it.
When I touched the Z-Steppers they were extremely hot. So I’m guessing they were being fed current when not needed, and had entered some kind of thermal overload. Everything is off now so they can cool down, and I’ll see if they are OK once they have cooled.
Here’s the steps I took leading up to this, in case something maybe relevant:
Before turning off the M4
- Dropped the router assembly all the way down, bottoming out Z, and then set Zero-Z.
- Entered the frames new width and height values in Config.
- Did a Retract All.
Turned off the M4, and did all the other things as listed above.
Turned the M4 back on
(Note that I did not redo config Zero Z again, I assumed that the non-volatile memory would be OK)
4. Raised the M4 by 30mm (no problems here)
5. Updated firmware and restarted M4. Updated index.html.gz and maslow.yaml (probably should not have done that last one)
6. Did a Retract All, and Extend All, then checked the Config and noticed that it had the wrong values for width, height and orientation.
7. Corrected the values, Retract All, Extend All … fine … put it on the frame, and then clicked Calibrate … nothing … checked the Config and noticed that the values had been zeroed?
8. Corrected the values again, still no Calibration action, Web UI was reporting problems and recommended a restart.
9. Did a restart, reentered the correct height, width and orientation, retract all, extend all, and put it up on the frame. This time Calibration worked (I have the logs), but in spite of statements about Zeroing z-axis position in the logs the Z-axis never moved.
10. Did a release tension, stuck a bit in the router, and then tried getting the router assembly to go down so I could set Z home, no action, check Z-Stepper motors - they were extremely hot.
11. After checking a few other things I decided to power down the M4 to reduce any further possible damage to the Z-Steppers.
