Ugh. I setup a new 4950x3150 “frame” using the 3d printed anchors glued to a concrete floor , with a 2400x1200 sheet in the middle as spoil board.
First calibration run had a terrible fitness score but completed the procedure without issue.
Serial Messages
$/axes/x/max_travel_mm=2438.400
$/axes/x/homing/mpos_mm=0.000
$/axes/x/homing/positive_direction=true
$/axes/y/max_travel_mm=1219.200
$/axes/y/homing/mpos_mm=0.000
$/axes/y/homing/positive_direction=true
[MSG:ERR: Calibration data not acknowledged by computer, resending]
CLBM:[{bl:2325.28, br:2363.43, tr:2360.48, tl:2362.99},{bl:2174.49, br:2176.45, tr:2562.44, tl:2590.23},{bl:1513.88, br:2866.65, tr:3173.03, tl:2075.02},{bl:1646.96, br:2973.33, tr:3079.84, tl:1870.12},{bl:1831.93, br:3080.19, tr:2969.67, tl:1682.54},{bl:2035.38, br:3205.85, tr:2880.00, tl:1518.80},{bl:2276.53, br:2894.26, tr:2524.56, tl:1839.87},{bl:2135.45, br:2750.98, tr:2596.45, tl:1978.17},{bl:1973.34, br:2627.08, tr:2717.81, tl:2134.31},{bl:1835.69, br:2525.36, tr:2857.22, tl:2308.25},{bl:2146.71, br:2176.56, tr:2594.59, tl:2596.48},{bl:2255.49, br:2292.59, tr:2433.95, tl:2436.25},{bl:2397.83, br:2432.91, tr:2292.84, tl:2295.30},{bl:2553.44, br:2589.30, tr:2175.53, tl:2178.12},{bl:2855.05, br:2318.80, tr:1836.66, tl:2523.38},{bl:2749.51, br:2137.36, tr:1945.09, tl:2635.23},{bl:2625.50, br:1975.31, tr:2107.26, tl:2753.38},{bl:2523.63, br:1837.85, tr:2284.49, tl:2890.37},{bl:2852.21, br:1516.56, tr:2072.29, tl:3206.03},{bl:2939.00, br:1680.53, tr:1867.13, tl:3081.68},{bl:3045.87, br:1865.14, tr:1679.25, tl:2971.56},{bl:3171.45, br:2065.07, tr:1515.07, tl:2882.06},]
Computing... This may take several minutes
Fitness: 0.013719239291010129 in 100
Fitness: 0.11208588594460811 in 200
Fitness: 0.1265253804978789 in 300
Fitness: 0.12662950327120728 in 400
Fitness: 0.12689730827713833 in 500
Fitness: 0.12710002768365702 in 600
Fitness: 0.12718271128078473 in 700
Fitness: 0.12726715459111998 in 800
Fitness: 0.12735304003614076 in 900
Fitness: 0.1274477048611932 in 1000
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
Calibration complete
Calibration values:
Maslow_tlX: -25.1
Maslow_tlY: 2195.7
Maslow_trX: 4145.4
Maslow_trY: 2186.0
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 4157.6
Maslow_brY: 0.0
I retracted, extended, and calibrated again, this time filming in case there was something obvious happening preventing a reasonable fitness score.
Bottom right belt let out too much slack and ate itself.
Could this be an issue with using a large frame size? anyone got any other ideas?
