Hi!
I bought a AEG MF 1400 KE router as recommended for EU. It was delivered with a 12mm collet and a 8mm collet.
Does anyone know where to get a 1/4" collet in Germany? Or is there an adapter?
Best regards,
Wolfgang
Hi!
Best regards,
Wolfgang
This is from https://www.fine-tools.com/oberfraese.html
6 mm collet not available for this router.
1/4 inch collet for this router is no longer available
A quick search on Giggle did not give other matches.
Viel Glueck! (Good luck)
For my Bosch I could buy metric and imperial from amazon(as)
PS: reducers (reduzierhuelsen) are not recommended for long term use.
You will be looking for something like this
Check dictum(dot)com. It takes some searching, but you can find bits with 8mm shaft and ~ pehaps down to 4mm cut diameter.
You will be ok with a 6mm bit with an 8mm shank. It’s close enough, provided the cutting depth is sufficient to pass through the material you are cutting. The Ground Control software will allow you to specify the appropriate diameter.
While this link won’t be the best for Europe you can use a 12mm to 1/4" sleeve. Giggle one for your area
4 pc Collet 12mm Reducer for 8mm, 1/4" Router Bit sct-888 https://www.amazon.com/dp/B07337MPN8
Thanks for your sugestions.
@mooselake: I found some for a reasonable price and will try them out.
Hi Wolfang. I’m in the UK and have same problem, where dis you find the 8mm and 12mm router bits?
Thanks!
Carlos
Hi!
I did not buy bits, i intend to use Maslows stock bits.
I bought these:
Did not test them jet.
Wolfgang
Hi The AEG MF 1400 KE router is a very expensive option in the UK. Is teh Bosh POF 1400 not any good?
Hi, stumbled upon this thread while googling for 1/4" collet for AEG 1400.
I finally found one in a Dutch shop: https://www.gereedschappro.nl/:
AEG Spantang 1/4"- 6,35 mm voor de AEG MF 1400
Artikelcode: 4002395829132
EAN code: 4002395829132
Hope this helps someone to find what you are looking for!
Hi Martin. Had the same problem,
Because I’m from the Netherlands to, I tried different options which didn;t work/fit. All my bits were 1/2 or 1/4 inch…
I could not get a 1/2 inch or a 1/4 inch for my AEG which only European model is which fit in the Jessem Routerlift 2.
Somewhere I’ve read that a Triton Collet fits the AEG. I could get it from the German Amazon; guess what, it fits perfectly.
So if someone has the same problem; the Triton TRC120 and the Triton TRC 140 fits!
