I have had problems removing the chains from the linkage. The cotter pins have to be replaced each time I do a new calibration with new software updates. Is there a better option to the split cotter pins?
Itās been posted to community garden. The svg file does not contain the toolpaths because, for whatever reason, I couldnāt save the svg with the toolpath added in makercam. So I included the gcode I used.
Thank you so much for the collaboration. Itās a great feeling to see an idea take effect. What files do we have up so far? @bee can you get these files ported over to desciples as the start of the open source file sharing as well.
can you take a picture of what you are using?
yes split pins are a bas idea.
also, you should start a new topic for a new problem
Good idea - I will check what is in the community Garden and go form there when I get a chance?
.I have used the cotter keys that came with the kit but I am now using
12ga. copper wire that I can bend easier. Hereās a pic.
You should be able to use the cotter pins which came with the original kit, right?
I use the pins that came with the original kit, but Iāve never bent them. They stay perfectly in place with the friction⦠they wont slide out on their own.
