this is a universal base plate capable of accepting various linkage and z axis solutions. It is open source so if you have access to a laser/plasma cutter I can send the DXF to you. https://www.2twentytwosteel.com/ did this prototype sled for $55 for us. We will be having it cut in bulk locally.
the vacuum port is just a 1 1/4 pvc wall mount
includes screws to attach above items to sled, just normal machine screws and nuts you can get at any hardware store
I ordered a sled. I have a ring kit, but I’m interested in the linkage setup and wonder if it might be reasonable to make a set of links. What reasons to do or not do that?
if you already have a ring setup just use that. the linkage kit works just as well and is less expensive to manufacture. The ring kit can be a little jerky as it moves, but I think with the heavy base and ultra low friction ring on bottom that might no longer be an issue.
I don’t think it’s that simple, part of the jerkyness of the ring is the
bearings rolling on the ring (or not doing so) This can cause a ripple on the
edge of your cut.
You have a very good machine if you get to the point that this is a significant
problem for you
I’m eyeing your z-axis upgrade kits. I already have a ring and the Ridgid router. Would you recommend the new base with ring and z-axis that is coming soon ($80) or your older one with linkage ($120)?
if you already have a ring I would wait for the new one. But if you are in a rush, get the current one. both work fine. The cheaper one is not painted or assembled in anyway (which is why it’s cheaper, less labor) plan on spending 1 to 2 hrs putting it together.
well with the coronavirus locking down china and my supplier LinkCNC not getting back to me timely. I really have no idea. I would guess sometime in March.
sorry no, holes for that 3d z are not laser cut, but you can always drill them yourself. the problem with 3d printing as a manufacturing solution is a lot of times it is simply cheaper and stronger to use other materials. especially when the volume is over 100 pieces.
