the outlet is not the problem. I use that outlet regularly and have a car battery tender plugged into it 24x7 and it never turns off. Probably a power supply or board issue with the Maslow. Just one more problem to deal with. The power supply is new as shipped - been used for 1 week so far before this happened.
@boslaw Will you start a new thread for your issue so that we can keep this one for @caddad?
I think that this is only true for the JST-XH encoder boards, the older ones with the ethernet connectors I think aren’t over the bearings enough, but I could be wrong about that.
Can you try swapping the wires around? Sometimes just unplugging and re-plugging everything can fix a connection issue like that
I’m having the same issue.
There are a LOT of different issues listed in this thread. Can you start a new thread describing your issue?
@bar I just swapped the cables around and have the same issue. test passed, but reading didn’t.
I echo starting new threads for issues not like mine.
If the test passes, but it’s not detecting any movement, there are two
possibilities
- the magnet is in the wrong place on that arm (or slipping)
- the encoder chip is working well enough to talk to the main board, but is
broken enough to not read.
it’s FAR more likely to be the magnet.
i wasnt having this issue before and its occurring with two encoders. I checked the magnet during reassembly per this thread’s emphasis. I only disassembled one arm.
could it be the main board?
I don’t think this is the magnet, this to me looks like there is something interrupting the communication between the main board and the encoder boards.
Since all of the encoders are on the same I2C bus something funky with the bus can impact multiple encoders. (IE a faulty connection to one might show up as one taking so long to respond that it messes up with the next one or something like that)
switch connectors around to see if the problem follows one arm.
bar will need to comment.
I am a little bit stumped.
I’m going to DM you a code for free replacement parts and I think it’s probably worth just getting a new controller, new wires, and four new encoder boards.
I’m pretty sure that only one of those things is needed, but the fastest way to find out which it is is to be able to swap each part out and see which fixes the issue.
You don’t need to take the whole machine apart to do that, the encoder boards will work plugged into the controller without being installed on the arms
Thank you! How do you suggest I determine the issue source once the parts arrive? It’s easiest for me to just swap everything out, but that wont help you for similar problems in the future.
I just realized, you might not have seen above that I already had the 4.1 upgrade. So I was using the new board and encoders. Sorry didn’t catch that before the order came in.
I sent you an email @bar about shipping costs being inaccurate on the site, but will also post here for others to know that upon taking the arms apart to replace the encoders, one of the idler gears was damaged and stuck in one of its bearings. I was gentle during initial assembly, so something happened during calibration. I am going to order a new idler gear and will hopefully get this this working!
I have the same calibration error that it keeps pumping out celebration fitness error I don’t know what to do everything else is working
My calibration at 7x7 took 3 hours and I finally got the calibrated message. I was elated but after so much time, I didn’t want to start a cut. When I came back later, I “extended all,” reconnected the belts to my frame and “applied tension.” When I attempted to jog, I got the message that “Maslow is not ready to move.” It is acting like it never completed calibration. I am using firmware ver. 6. I disconnected the belts, retracted all, extended all, reconnected the belts, applied tension. When I attempted to jog, I received the same message. Am I missing something?
version 0.6?? that is really old.
what are the contents of your maslow.yaml file? save a copy of that and upgrade
to the current version.
once you get to a current version it will be much easier to help you.
You misunderstood. I have firmware Version 6.1 (fairly recent build) and machine 4.0.
Correction: firmware version 1.6.
Hi I just asembled my Maslow and started the calibration process, done all the frimware update, after I retracted all belts without any problem, when I satrted extend them I realised on one belt has a damage.
Anybody has the same issue? what can cause? How to prevent?
I cut that piece off, was 500mm from the end, but I dont want to chop all my belts unable to move all the working area
Thx A
please start a new thread for this issue.
