4.1 Calibration Issues and Questions
Stephen Roberts wrote:
You misunderstood. I have firmware Version 6.1 (fairly recent build) and
machine 4.0.
the latest firmware release is 1.07, where did you get firmware 6.1?
Correction: firmware version 1.6.
ok, that makes far more sense :slight_smile:
check the release notes for later versions to see if they address your issue.
also, go to the test page and make sure the firmware and index.html versions
match.
Okay, my next question is what to do if I wrote any size for Extend distant at Calibration the belts came out around 1850(what is too long), then I hang it on the anchor points start calibrating but shortly stops it with Frame size error msg, I tired several times but same
Can you post the error message? I’m not sure which one that is :grinning_face:
Ah I would recommend doing a firmware update. There have been some pretty substantial improvements to the calibration process and that error is handled automatically now by the machine.
Heres a walkthrough for that process:
and what in case of this?
Could the zip file still be zipped?
no, I extracted fully
Is the install-fs.bat file still in the same folder?
What that error message is saying is that it can’t find the other files that should be in the same folder I think
Can you try downloading it again? It seems like there is something funky going on with the files, but I’m not enough of a windows expert to know what it is
the same version?
this time is do something but then aksking me to select com port (choose 1) then?
Great! You should be done and you shouldn’t ever need to do that again :grinning_face:
