I ran a calibration today and realized where I went wrong and have some observations based on this frame. I have a 8’ W x 12` H at 15% slope. I used 600,600 offset and 2438.000 x 3658.000 for the anchor point coordinates.
Here are the results: Fitness 0.0384… 9700 cycles. WARNING FITNESS TOO LOW…
Observations:
on the top and bottom and right the sled leaned over the spoilboard a bit, (especially on the right, which I anticipated and had a 1x3 up to prevent it from getting caught up in the frame…
when moving from left to right (both on top and bottom of pattern), the maslow did not let up slack on the bottom left belt so it pulled tightly before it moved over, and there were a number of “over voltage” warnings/errors during some of these.
the maslow was very tipped. I wonder if the anchor points need to be raised up because it seemed to tip upward a LOT during (especially the top half) of the calibrations.
Is there any data I can gather post mortem? I was not able to capture the output with copy/paste as I can’t seem to get the ipad to select all the data in the terminal window under the maslow controls. I took a lot of pictures of it, which I will post some stills.
I also noticed that the bottom right was getting caught on the dust hood and as I’m looking at it it looks reversed from what it ought to be, or I put the arms on in the wrong order. (bottom-right is on the bottom)
Advice? should I increase the offsets and try again?
I wouldn’t expect it to be tipping, that seems like something is up. Is it possible to capture a picture of that?
The first thing that I would try is to do Retract All → Extend All → Retract All and confirm that all the reported numbers are close to zero. That will tell us that there isn’t a magnet slipping which seems to be reasonably common.
If that looks good, I would try a really small pattern like 2x2 with large offsets close to the center of the sheet, like maybe 100mm square.
(I think we should switch from using the offsets to using the size of the calibration grid so I could say “2x2 points on a 100mmx100mm grid”)
Here are a couple of shots. it looked more drastic in person also, I think the other instances were because the sled was over the edge of the spoilboard at least a litte.
after watching it go through this calibration, I think a tall vertical frame may not work as well as other orientations, at least for calibration. on the lower side, I don’t think it got very good measurements, as it moved from side to side quite a bit during the bottom belt tightening phase as the geometry of the belts seems to make this worse, the lower it goes. I’m not sure I’m phrasing that right, but maybe you get what I’m saying…
So I snuck out during lunch and grabbed my maslow and re-assmbled the arms in the correct orientation. The installation gif is good, and I’m not sure how I did it in the wrong order before.
I did retract all / extend all / retract all and got:
[MSG:INFO: 3 pulled tight with offset -0.011]
[MSG:INFO: 2 pulled tight with offset 0.000]
[MSG:INFO: 0 pulled tight with offset -0.043]
[MSG:INFO: 1 pulled tight with offset -8.814]
[MSG:INFO: 0 pulled tight with offset 0.021]
[MSG:INFO: 3 pulled tight with offset 0.150]
[MSG:INFO: 1 pulled tight with offset 0.043]
[MSG:INFO: 2 pulled tight with offset 0.054]
I’ll try a smaller calibrate tonight… lunch is over
Also had a side thought… I wonder if it would be useful to have a way to test your arms before getting things all assembled? it would be a “nice to have” for sure. taking things apart is not exactly a fast process.
Also brings up another question I had… Do you think it would be ok to run calibration without the linear rail supports/handles on? I’d think so as they probably are not getting any stress during calibration, with Z all the way down. Just going to save me some time as I will wait for my new arm/belt before doing any final calibration, since my top-right and bottom right belts are a little chewed up toward the inside of the spool from the tangle a few days ago.
If needed, a separate tab, but could be a pulldown menu item
It’s not something you normally do, this is ‘expert mode’ type stuff (as
discussed elsewhere in the problems of writing software for non-experts to use)
