I know it has been talked about in the past. But I was wondering what that accuracy is now in the corners with a Maslow? I am basically going to be using it for decoractions or other items that have a little give in the accuracy.
We can’t answer that. We can approximate & I bet @Dlang will be able to give you some guidance. I say this because it depends on how you build your Maslow. There are too many variables in how and what you choose to make your Maslow frame.
we don’t have a really good answer, we think we are around ±1mm in the corners
with a well build and calibrated frame.
but more testing is needed (especially with the new ring mount)
k
Awesome so it shouldn’t be a drastic difference for what I will be doing with it. I can understand how it could be for some. Thanks
