Adjusting distance between home cutting and start on design
Hello all
I’m new to Maslow and thru trial and error have been able to cut a few projects. I want to know if there is a way of shortening the distance between where Maslow starts in gc and the first plunge for a cut. My setup area is tight and often I have to start in a corner in order to set home to keep my design on my 4x8 sheet.
Any and all help is appreciated.
Thanks
that is done in the CAM step of your design, what software are you using?
there are also online g-code optimizer programs available that can re-order your
g-code to reduce movement
Easel. Please and thanks
Basically the starting position of maslow will be the 0,0 point on your drawing in easel. You can move that point around using the “Define Home” button. I believe that in easel 0,0 is the lower left hand corner of the screen so moving your design closer to there should help.
Maybe I am misunderstanding the question, some screenshots could help us to help
