So, new to the Maslow, and new to Ground Control but not to Easel or CNC. I’ve been working with an X-Carve for about 4 years now.
Presently for the Maslow I’m generating G-Code using Easel. Problem I’m having is Easel naturally assumes that your machine’s home position is the lower left hand corner of the your work piece. Ground Control, when setup using the how-to documentation for the Maslow, sets the home position to the center of the work piece. This means if you try to cut without any adjustments unless you’re cutting things that are 2 by 4 you’re going to have some serious problems.
What is the best way to fix this problem? Again I’m new to GC so I’m a little hesitant to just start trying and praying without some advice. Does the home area need to be redefined to the lower left in GC? If so is there a good how to using the Maslow on doing this?
Is there an adjustment to the gcode that needs to be done when using Easel in this way? Is there some way to fake Easel out so that it understands home is in the middle of the work area?
I’m sure this is a total newbie question, but I’m having a lot of problems navigating the Maslow documentation on stuff like this so any assistance is appreciated.
