I’ve been keeping backups of my groundcontrol.ini files in a separate folder from ground control:
That way I can restore to a previous version if I change configurations at any point. I usually use it as a starting point, and then run a couple rounds of calibration to make sure that the settings accommodate this iteration of the configuration.
Is there a way to automate the backup process through Ground Control? For instance, when you click it, it creates a backup of the .ini file in C:\Maslow\INI_Backup, then restores the settings to default? Not that I’m opposed to copying the files manually, but it would be pretty cool to be able to press a button and then back up the settings. If I had more coding knowledge/time I would take a crack at it in a fork.
