I have GC installed on 2 laptops because I grabbed the wrong one at one point. I now have my Maslow and GC all set up and working great on the wrong laptop. Which files do I need to move over to the other to transfer all my settings?
‘groundcontrol.ini’ is the file you need. It is found in your home directory. The serial connection and the path to the .nc file will probably be different on a different PC, but everything else will be the same.
Awesome, Ill swap it over now!
Is this still correct? i could not find the file in question.
It is. Are you running win?
Edit: If so, the path to look would be:
C:\Users\{your user name}
For linux:
/home/<loged_in_user>/groundcontrol.ini
