Upon loading ground control all my setting reverted to default. The back ground command prompt says “unable to write the config…” When I try to run the calibration. I had power issues and reset the eeprom on the motors then redid my calibration. If I do not close ground control it works perfect.
Hi, on what operating system are you running GC? Are you able to locate your groundcontrol.ini file in your user folder?
Thank you, when I went to look for them apparently I must have recently hidden them. Just unhiding them now. Feel like a dumbass.
