Andy_Boles Dead Stick Malsow 4.1. Brand New out of the box Corupt Fimware 1.22?
That makes sense, you have more experience than me then. So machine an program problem.
Does it do the same wobble if you do an air cut?
Did you figure it out? I am starting on some larger cuts this week with 1.22 or 1.23.
Honestly, I put this on hold for the last two weeks and focused on a different project. I have not found a solution. I had to make my project by hand, but I hope to work through it soon. I’m thinking that using the Maslow in the vertical orientation will not work well and needs to be flat on the ground. This defeats the whole reason I have the Maslow, which is the safe floor space
Sadness. Maybe I will try some stuff I don’t care as much about in vertical mode with 1.23 to see what happens.
