[MSG:ERR: Invalid setting or command: /Maslow_Calibration_Current_Threshold]
I just built my machine and plugged it in here at my desk. I am able to TEST, RETRACT and EXTEND. I am not able to move my z axis. The motors do activate and make a noise but, I have no movement. Any suggestions.
That sounds to me like there is something funky with your Maslow.yaml file which holds all of the settings.
The easiest thing to do is to delete that file and grab a fresh one from the latest firmware
When I try to delete the old YAML the message says says “delete TEMP.NC” is this normal?
I think the machine i just received July 1 2026 bricked somehow during firmware update to 1.22.0 I’ve attempted to update the YAML and other .bx files, though I have no confirmation. I Get These errors: Serial Messages
Index.html Version: 1.04
[MSG:INFO: FluidNC v1.22.0]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 6]
[MSG:INFO: Axis A (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: tmc_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor1]
[MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:gpio.38 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor0]
[MSG:INFO: Connecting to STA SSID:NETGEAR88]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.68.127]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://maslow.local/\]
[MSG:INFO: WebSocket send protection active (canSend() checks enabled)]
[MSG:INFO: SSDP Started]
Grbl 1.22 [FluidNC v1.22.0 (wifi) ‘$’ for help]
[MSG:INFO: ‘$H’|‘$X’ to unlock]
[MSG:ERR: MaslowKinematics not available]
[MSG:INFO: Current z-axis position loaded as: 0.000]
[MSG:INFO: Saved belt positions in NVS are marked as stale/invalid (value=0) - machine will remain in UNKNOWN state until belts are calibrated/extended]
[MSG:INFO: Starting Maslow Version v1.22.0-dirty]
[MSG:INFO: Maslow_Retract_Current_Threshold: 900]
[MSG:INFO: Maslow update loop registered with hardware watchdog]
[MSG:INFO: TLC: 4.800 TRC: 3.000 BLC: 1.900 BRC: 7.900]
[MSG:INFO: TLC: 0.900 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 1.200 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 0.800 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 0.500 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 2.500 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 2.100 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 1.100 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 2.700 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 2.400 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 0.700 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 0.200 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: TLC: 1.000 TRC: 0.000 BLC: 0.000 BRC: 0.000]
[MSG:INFO: Zm=0.000mm, Z home=0.000mm, Z position=0.000mm]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_beltEndExtension]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_armLength]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_trX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_trY]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_trZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlY]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_brX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_brZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_blZ]
error:3
I haven’t seen that, but I think that deleting the maslow.yaml file is the right move. I think that the other errors that you are seeing are coming from an old version of that file.
You don’t have to actually delete it, just uploading a new one will replace the existing one which might be easier if you are getting a weird message
You need to update the index.html.gz file, it is an old version. Make sure the file still has the gz extension when you load it, use the 1st Green tab under FluidNC to update.
Thanks for the effort. When I delete the index.html.gz file it shows this window. However the file doesn’t disappear after deletion, nor does the file size change when I download the new file from the 1.22 repository. I’ve tried this with the 1.21 firmware and support files too.
I reverted to Firmware 1.04.0 hoping that the firmware will match the html and yaml files.
I get this now:
It says it needs an idle state and I need to unlock the machine to jog the z axis? (see the end of this code)
Serial Messages
[MSG:WARN: Ignored key Maslow_Apply_Tension_Belt_Retraction_Limit]
[MSG:WARN: Ignored key Maslow_Apply_Tension_Allow_Limiting]
[MSG:WARN: Ignored key Maslow_Scale_X]
[MSG:WARN: Ignored key Maslow_Scale_Y]
[MSG:WARN: Ignored key Maslow_debugEnabled]
[MSG:WARN: Ignored key Maslow_Work_Area_X]
[MSG:WARN: Ignored key Maslow_Work_Area_Y]
[MSG:WARN: Ignored key Maslow_Work_Area_Center_Offset_X]
[MSG:WARN: Ignored key Maslow_Work_Area_Center_Offset_Y]
[MSG:WARN: Ignored key Maslow_spoilboardThickness]
[MSG:WARN: Ignored key Maslow_workThickness]
[MSG:WARN: Ignored key Maslow_Park_Z]
[MSG:WARN: Ignored key Maslow_Park_X]
[MSG:WARN: Ignored key Maslow_Park_Y]
[MSG:WARN: Ignored key d]
[MSG:ERR: Skipping key steps_per_mm indent 4 this indent 2]
[MSG:ERR: Skipping key max_rate_mm_per_min indent 4 this indent 2]
[MSG:ERR: Skipping key acceleration_mm_per_sec2 indent 4 this indent 2]
[MSG:ERR: Skipping key max_travel_mm indent 4 this indent 2]
[MSG:ERR: Skipping key soft_limits indent 4 this indent 2]
[MSG:ERR: Skipping key homing indent 4 this indent 2]
[MSG:ERR: Skipping key cycle indent 6 this indent 2]
[MSG:ERR: Skipping key allow_single_axis indent 6 this indent 2]
[MSG:ERR: Skipping key positive_direction indent 6 this indent 2]
[MSG:ERR: Skipping key mpos_mm indent 6 this indent 2]
[MSG:ERR: Skipping key feed_mm_per_min indent 6 this indent 2]
[MSG:ERR: Skipping key seek_mm_per_min indent 6 this indent 2]
[MSG:ERR: Skipping key settle_ms indent 6 this indent 2]
[MSG:ERR: Skipping key seek_scaler indent 6 this indent 2]
[MSG:ERR: Skipping key feed_scaler indent 6 this indent 2]
[MSG:ERR: Skipping key motor0 indent 4 this indent 2]
[MSG:ERR: Skipping key limit_neg_pin indent 6 this indent 2]
[MSG:ERR: Skipping key limit_pos_pin indent 6 this indent 2]
[MSG:ERR: Skipping key limit_all_pin indent 6 this indent 2]
[MSG:ERR: Skipping key hard_limits indent 6 this indent 2]
[MSG:ERR: Skipping key pulloff_mm indent 6 this indent 2]
[MSG:ERR: Skipping key null_motor indent 6 this indent 2]
[MSG:INFO: Motor0]
[MSG:INFO: Axis Y (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO:this indent 2]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: WiFi on]
JogTo: '$J=G91F300Z-10
error:8 - Command requires idle state. Unlock machine?
Click on the Red Alarm on that version
This is what I see when I go to the FluidCNC Settings
You don’t need to delete the files, just update them. The easiest way is to go to the FluidNC tab, click on the Manage local files (green button), then Upload and then go to where you save the update files (normally Downloads in windows) and select index.html.gz. After it loads close that window, On the FluidNC settings select the Orange Button (Upload Firmware file) Select File and you should have a firmware.bin available. Load it and the Maslow should restart with the new versions loaded.
Power Off the Maslow, restart and refresh the browser. If that doesn’t fix it, it will need a factory reset.
Still Shows mismatch between versions. What Do I need to do for a firmware Factory reset?
The upload files feature isn’t replacing those files
BTW, I see you use the maslow to make theater sets. I’ve made several props for my local theater and I’d like to use this for the same purpose eventually, lol :wink:
How do I do a factory reset? I have a USB C cord ready to go
Are you still seeing failed 406?
To do a factory reset you need a USB data cable connected to the Maslow and your PC
You also need to unpack the latest update file For Mac
https://github.com/MaslowCNC/Maslow_4/releases/download/v1.22.0/fluidnc-maslow4-1.22.0-posix.zip
or Windows
fluidnc-maslow4-1.22.0-win64.zip
Where the video says version 1.0 substitute version 1.22
(1) Installing Firmware 1.0 - YouTube
If you can still get to FluidMCs menu it is much easier to load files from those menus
Thanks I’ll try that. Interesting note:
When I use FireFox browser to change those files, it goes to a dialog box and allows you to browse to the file you want. However, in Chrome browser, it actually downloads that file from the machine to my download folder…
If you lift the Maslow off the screws, do they rotate without a load? Is it both or only one not working?
Serial Messages
Index.html Version: v1.22.0-dirty
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:NO_PIN Disable:NO_PIN R:0.11]
[MSG:INFO: WiFi on]
[MSG:INFO: Error ESP_ERR_NVS_NOT_FOUND reading from NVS!]
[MSG:INFO: Maslow_Retract_Current_Threshold: 1300]
JogTo: $J=G91G21F300Z1 (mm)
Maslow is not ready to move.
Could not perform Jog. Belt lengths are unknown.
Set Z-Stop
[G92:0.000,0.000,0.000,0.000,0.000]
[G54:0.000,0.000,0.000,0.000,0.000]
Test
[MSG:INFO: Firmware Version: v1.22.0-dirty]
[MSG:INFO: I2C Timeout: ]
[MSG:INFO: 10]
[MSG:INFO: All tests passed on Top Left]
[MSG:INFO: All tests passed on Top Right]
[MSG:INFO: All tests passed on Bottom Left]
[MSG:INFO: All tests passed on Bottom Right]
Stop
[MSG:INFO: Raising Z from work Z 0.000mm to 2.000mm (Z home + 2.000mm)]
[MSG:INFO: Zm=2.000mm, Z home=0.000mm, Z position=2.000mm]
JogTo: $J=G91G21F300Z-1 (mm)
JogTo: $J=G91G21F300Z-5 (mm)
JogTo: $J=G91G21F300Z-3 (mm)
Retract All
[MSG:INFO: Succeeded]
[MSG:INFO: Zm=-31.000mm, Z home=0.000mm, Z position=-31.000mm]
[MSG:INFO: Bottom Right pulled tight with offset -1671.351]
[MSG:INFO: Top Right pulled tight with offset -1736.989]
[MSG:INFO: Top Left pulled tight with offset -1780.169]
[MSG:INFO: Bottom Left pulled tight with offset -2134.963]
Extend All
Set Z-Stop
Find Anchors
[MSG:INFO: Requesting state change from Extending Belts to Finding Anchor]
[MSG:INFO: Cannot start Find Anchors until the belts have been extended]
Apply Tension
[MSG:INFO: Requesting state change from Extending Belts to Taking Slack]
[MSG:INFO: Cannot take slack until the belts have been extended]
post by Andy_Boles 13 mins ago
post by Andy_Boles 8 mins ago
@bar
So the hard reset via usb did work, but it won’t find the anchorpoints.
  1. retract
  2. extend and set anchors
  3. request ‘Find anchors’
    3a: verify z axis down
    3a.1: Yes
    3b: Error: Can’t find anchors until belts are extended
IDK but thanks for the help
