Thanks, does Ground Control prompt you to change bits when it realizes the bits are different on the different pages? I know that feature exists just wondering if that change in Easel is detected by GC.
You will end up with two .nc files. I name them by the bit (16th and 8th) so that I know what bit is used for each map. Each page then has a different bit as well as a different CAD file. In reality you could do the same if you just made two fully separate Easel files.
Here is the link to my Easel project for this map, I hope it gives you more idea of the process.
http://easel.inventables.com/projects/EKFgCgTBt6xtVcw79Qanvw
Any chance you will be doing Conroe Tx?
@brazz04, I tried to open your Easel file but it says it hasn’t been shared publically so won’t let me view it.
Here’s another try, I don’t think i hit save after I shared it.
Bee, I don’t have any plans to do conroe right now but I will look into it for the future!
Worked! Thanks for your help and your time! (Sent from sitting next to the running Maslow)
I only ask because I might buy a place there. Just down the road a bit from Austin.
