Hello All,
Let me start out by saying I am really looking forward to starting to cut, I have assembled the Maslow but I am stuck there.
I have been able to setup the wifi connection and even retract the belts. But now I cannot extend any of the belts 2 of the belt encoders show a yellow and green light (TR&BR) and the other 2 (TL&BL)show only green on the cards. I have swapped the ethernet cables to other channels and the board led display the same lights. FluidNC does readout they are retracted and gives an offset for each one.
I have tried to update the firmware using Fluidterm and get a reply of no serial port found. So I have been unsuccess with updating. I have even tried to update the maslow.yaml file using the the Wifi connection and that errors (but I don’t remember the error code. Sorry)
Final question for now. Does the cooling fan run continuously or does it cycle on/off as need? Because my fan has never turned on even when I try to extend the belts.
I am sure I will have more questions as I progress coding is not my area, but I can cam and have been running CNC machines for years.
Thanks for your help.
