I am running the latest firmware and using the Maslow on a frame. This has never been an issue until now; however, I don’t cut much.
I am having an issue I wanted to run by the group before moving forward. I was using the M4 to make a few basic cutouts, for the most part, squares. I did two back-to-back, and both had the same issue, so I stopped.
In short, the top-right mounted motor, or the second from the cutting surface, is locking, jumping, or slipping. When cutting one of these squares, it should have made 4 passes. On the fourth pass, when the Maslow is in the lower right corner of the cut, either right in the corner when it adjusts to start moving up, or shortly after starting to move up, the unit jumps a little to the left, taking the bit into parts of the board it has not passed yet. This jams the system and causes it to lock up.
I stop the router and maslow, then have to fight to clear everything. This takes a few power cycles, and I have to fight with belt tension to get the Maslow free from the board. After I disconnect the belts from the corner, I have to release tension, extend, and retract a few times before the second motor and belt start responding. It feels like the belt may be slack within the Maslow. After a few tries, it finally responds, and then the unit starts acting normally again.
I plan to do a few more small cuts to test this further, but if you have any suggestions on what I should look for, I am all ears.
