It seems I have a problem with one of the motors (bottom right): it is winding the belt in a jerky, uneven manner. Consequently, when the machine moves to the right, it creates ripples in cuts that should be straight. Have any of you encountered this issue before?Thanks for your reply.Maslow 4 firware 1.2 Pierre (Brittany region, France)
Usually when you see behavior like that it is caused by two of the motors fighting against each-other due to the machine not having a good sense of where the anchor points are located.
The first thing that I would try is to re-run the locating anchors process.
It can also be caused by one of the motors working too hard and the driver overheating. What do you have the retraction force set to and do all of the belts seem to retract and extend smoothly?
