Hi David,
I have changed those values to the same as my retraction value (2400). I followed the advice to manually take up the slack during calibrations too. It now seems that I am getting a warning about my fitness levels at the end of the cali. I have attached the results. Do you have any advice on how to fix this?
[MSG:INFO: Zeroing z-axis position]
[MSG:INFO: Center point deviation: TL: 0.237 TR: 0.292 BL: 26.741 BR: 23.826]
[MSG:ERR: Measurement error, measurements are not within 2.5 mm of each other, trying again]
[MSG:INFO: Max deviation: 3.135]
[MSG:INFO: Bottom Right 2167.135]
[MSG:INFO: Bottom Right 2167.114]
[MSG:INFO: Bottom Right 2167.146]
[MSG:INFO: Bottom Right 2167.157]
[MSG:INFO: Top Right 2477.397]
[MSG:INFO: Top Right 2477.204]
[MSG:INFO: Top Right 2477.129]
[MSG:INFO: Top Right 2477.107]
[MSG:INFO: Top Left 1897.713]
[MSG:INFO: Top Left 1900.848]
[MSG:INFO: Top Left 1900.998]
[MSG:INFO: Top Left 1901.127]
[MSG:INFO: Bottom Left 2253.142]
[MSG:INFO: Bottom Left 2252.970]
[MSG:INFO: Bottom Left 2251.370]
[MSG:INFO: Bottom Left 2251.392]
CLBM:[{bl:2205.70, br:2203.92, tr:2179.71, tl:2181.23},{bl:2103.02, br:2096.23, tr:2285.67, tl:2286.84},{bl:1903.21, br:2251.30, tr:2476.98, tl:2167.18},{bl:2065.00, br:2329.67, tr:2325.56, tl:2055.54},{bl:2189.68, br:2443.89, tr:2228.89, tl:1945.49},{bl:2322.55, br:2327.61, tr:2076.33, tl:2077.80},{bl:2442.03, br:2191.65, tr:1943.81, tl:2230.41},{bl:2331.47, br:2065.46, tr:2053.97, tl:2327.04},{bl:2242.44, br:1960.07, tr:2165.76, tl:2426.17},]
Computing… This may take several minutes
Computing… This may take several minutesFitness: 0.1513519 in 100
Fitness: 0.1513519 in 200
Fitness: 0.1513519 in 300
Fitness: 0.1513519 in 400
Fitness: 0.1513519 in 500
Fitness: 0.1513519 in 600
Fitness: 0.1513519 in 700
Fitness: 0.1513519 in 800
Fitness: 0.1513519 in 900
Fitness: 0.1513519 in 1000
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
