I tried a few calibration runs with 0.70 tonight and wanted to share the results.
Summary: Calibration process worked well but failed to find a suitable fitness. The problem seemed to get worse on the second run. When on the outer 9x9 square, it seems there is an issue where 1 of the 4 belts will tighten, another belt will tighten, then the first belt will slack.
I did an initial calibration run using 9x9 with 1800x1600mm calibration area (my machine is 2240x2130mm). It proceeded through all the stages but on the last (9x9) stage I noticed that 1 of the 4 belts was consistently loose when taking a measurement. That belt was originally tight but developed slack as the other belt was tightened. I recorded a short video that shows the behavior. I didn’t see this on the 3x3, 5x5, or 7x7 steps. (Could it be that the software assumes it will stay tight but with the long lengths when the 2nd belt tightens it moves the sled enough to put slack back in the first belt?). The first 3 steps all had Fitness values >0.5 and save the calibration settings. But on the 9x9 the fitness was too low.
I think repeated the calibration process from the beginning again. On the second attempt, from the beginning the machine seemed to keep all 4 belts much tighter when moving (I assumed because we had improved info from the first calibration run). The 3x3 completed with an OK fitness (but significantly less than the fitness for the 3x3 on the first run). On the 5x5 step, the fitness was too low and it stopped there.
I was hoping that sequential calibration runs would improve the results but they instead seemed to become worse. I’m not at all sure whether to keep trying additional runs give the result is getting worse.
Open to all ideas about what my next step should be…
Attaching the logs from both the first and second calibration run and the video.
0.70 Calibration Run 2.txt (6.0 KB)
0.70 Calbration Run 1.txt (15.4 KB)
