Not quite sure what’s going on here, but for the last two cuts the belts have gone slack early on in the cut.
Here’s the whole serial.log
Serial Messages
Index.html Version: 0.83
[MSG:INFO: FluidNC v0.84 (Add-setting-for-scaling-move-dist-b0d457f6-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:TP-Link_5CB2]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.1.106]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
FO: Z Axis driver test passed]
[MSG:INFO: WiFi on]
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Top Right pulled tight with offset -1208.808]
[MSG:INFO: Bottom Right pulled tight with offset -1289.264]
[MSG:INFO: Bottom Left pulled tight with offset -2584.154]
[MSG:INFO: Top Left pulled tight with offset -2656.923]
Jog: Z2
Jog: Z2
Jog: Z1
Jog: Z0.5
Home pos set for: Z
[G54:250.000,-300.000,72.850]
Jog: Z3
[MSG:INFO: Top Right pulled tight with offset 0.097]
[MSG:INFO: Bottom Left pulled tight with offset 0.011]
[MSG:INFO: Bottom Right pulled tight with offset -0.107]
[MSG:INFO: Top Left pulled tight with offset -0.021]
[MSG:INFO: Center point deviation: TL: 0.262 TR: 0.241 BL: 0.020 BR: -1.718]
[MSG:INFO: Center point deviation within 15.000mm, your coordinate system is accurate]
[TLO:0.000]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.011mm Counter: 1]
[MSG:WARN: Previous error was 15.011mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.054mm Counter: 2]
[MSG:WARN: Previous error was 15.054mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.097mm Counter: 3]
[MSG:WARN: Previous error was 15.097mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.129mm Counter: 4]
[MSG:WARN: Previous error was 15.129mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.179mm Counter: 5]
[MSG:WARN: Previous error was 15.179mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.214mm Counter: 6]
[MSG:WARN: Previous error was 15.214mm]
[MSG:INFO: Reset during file job at line: 68]
[MSG:ERR: Position error > 15mm while running. E-Stop triggered.]
My plan is to update the software first. But any other pointers?
